Z51 Cross Drilled Rotors on 2002 TransAm
Would 2005 Z51 Cross Drilled Rotors fit a 2002 Pontiac TransAm WS6?
The size of the rotors are
front: 13.4 x 1.26 / 340 x 32
rear: 13 x 1 / 330 x 26
Like trackbird said no. First you would need special brackets to move the caliper so you could fit the rotor under it. Not mant people are going to go threw that much trouble. 2nd it would not even clear a wheel smaller then 18". If you want a bigger rotor, do a brake upgrade kit like SSBC,Stoptech, Brembo, Porsche, Wilwood, or the LG C5 kit like mine.
