Poly bushings - Recommendations?
I'm looking to stiffen things up a little, without making major changes (yet). This is a street only car. I'm thinking of poly bushings for the following components:
Front and rear sway bar D-bushings
Front and rear sway bar end links
Transmission mount
Are there any other busings I should seriously consider? I'm probably going to replace the LCA's some time soon, so I'm not going to buy bushings for those. First I gotta get some relocation brackets, though.
-Mike
Transmission mount
-Mike
Do a search using 1LE Bushings. From your signature, you have 1LE swaybars. You'll get a ton of info back. It's a question that has been talked about quite often. Here's one link I pulled up, but that's not all. You'll have to look for additional ones.
https://ls1tech.com/forums/showthrea...t=1LE+bushings
