Traction Control
Old Mar 18, 2005 | 07:57 PM
RedWS601's Avatar
Default Traction Control
HOw do you know if you have traction control? My low trac light comes on when I peel or blast off?
Old Mar 18, 2005 | 08:14 PM
felton316's Avatar
You would have a button to disable it. When you press the button, a little light on the instrument cluster would light up reminding you that its off. The low trac light will come on on all F-bodies.
Old Mar 18, 2005 | 10:30 PM
TooSlow02's Avatar
You should have a button marked TCS on your dash. If you spin the tires and the low trac light comes on, you have traction control. You should also feel the gas pedal kick back at your foot. Otherwise, it will only come on when the ABS activates.
Old Mar 22, 2005 | 02:03 PM
RedWS601's Avatar
So I guess I don't have it because the low trac light does come on but I don't have TCS button. So I don't need that TCS reversal from SLP, right?
Old Mar 22, 2005 | 03:45 PM
trackbird's Avatar
Can you do a burnout? If you can smoke the tires, you don't have it. It will nearly kill the engine if it's turned on (I have it) and you try a burnout. The low track light can be driven by the abs system seeing a difference in wheel speed and calculating that there has been a loss of traction.
Old Mar 22, 2005 | 07:21 PM
Ptvolly's Avatar
Nope, don't need it!
Old Mar 22, 2005 | 11:28 PM
12stones's Avatar
On a T/A i think the button is to the left of the cigarette lighter. "low track" dosn't mean you have Traction control, my old T/A would set off the 'low trac' light whenever i'd burnout, or slid around, but it didnt' have traction control.
Old Mar 23, 2005 | 01:23 AM
Martingale's Avatar
Yep, look to the left of the cig lighter right behind the shifter. If there's a botton that says TCS there you have traction control, if it's a pocket about the size of a pack of cigs you don't have it.
Old Mar 24, 2005 | 10:22 PM
TooSlow02's Avatar
Sounds like you don't have it. In that case, you don't need the logic module. Have fun smokin' up.
