What lowering spring kit ?
Thanks,
Kevin
Springs - I personally like Hotchkis. You could also get a good coilover kit.
Shocks - Koni SA's or revalved Bilsteins. I got cheap-o KYB shocks and they're better than stock, but only a little. Had I to do it over again, I would get better shocks.
Adjustable panhard rod - When you lower the rear-end, it WILL shift out of center. An adjustbale PHR will fix this and is an easy install while you have the rear-end up in the air.
LCA relocation brakcets - When you lower the car, the lower control arms end up either level or angled higher in the back than the front. This impairs their usefulness. LCA relocation brackets fix this and are another easy install. I bought bolt-in brackets and they made a big difference in traction.
It's a lot of money, but if you do it all at once, you won't regret it.
-Mike
Kevin
