Are "Trailing Arms" and "Control Arms" the same thing?
Old Mar 27, 2005 | 04:26 PM
Tiremarx723's Avatar
Default Are "Trailing Arms" and "Control Arms" the same thing?
Im not a suspension genious, but whats the diff or are they the same?
Edit: Im talking rear-end only here
Old Mar 28, 2005 | 09:38 AM
any1?
Old Mar 28, 2005 | 10:19 AM
trackbird's Avatar
On the rear, your control arms are "trailing arms".
On the front your control arms are an "A arm" style and not a trailing arm.
The trailing arms "trail" behind their mounting point and are typically straight (like our lower control arms on the rear).
So, the answer to your question is "it depends on which end of the car we're talking about. If it's the rear, it's yes."
Old Mar 28, 2005 | 11:04 AM
that what i was thinking, thanks!
Old Mar 28, 2005 | 12:00 PM
TWS's Avatar
TWS
Technically no, but realistically some people use the terms interchangably.
My '72 Vette had TRAILING ARMS. My 4th Gen F-bods have LCAs. The trailing arms had a lot more stuffed in the them/bolted on them. In fact the halfshafts connected right to the inner side of them via a u-joint from the differential. The LCAs, as you know, as simple pieces of metal with two bushing ends.
These days you can use the terms interchangeably and prolly no one will give you a hard time besides maybe some purists.
