DMS spring owners. Come in.
Old Mar 27, 2005 | 11:25 PM
ritz's Avatar
Default DMS spring owners. Come in.
Well I've been going back and forth between these and Hotchkis. I've heard nothing but good things about them both and the price tag on the DMS springs makes me lean towards them even more.
My main concern is ride height. They have an advertised drop of 1.3" which of course is most likely gonna be more once they've settled, but I was looking at some customer cars and they look slammed in the front while others ones don't.
If anyone that has these springs can please come in and help me out I'd appreciate it because I really like the sound of them and their price, but I'm just kinda stumped on why some of the cars look slammed in the front and some don't. I don't wanna have that look. Wheel tuck makes baby Jesus cry.
Here's the pics...http://www.dynamicmotorsports.com/Springs%20Pics).htm
Old Mar 30, 2005 | 09:44 AM
IRACE2's Avatar
I think DMS springs look good. They do have the racked look though. Pics are in my sig. Before and after.
Old Mar 30, 2005 | 12:21 PM
SStick Bandit's Avatar
I think the ride height on the DMS springs are perfect. I can go over speed bumps and rarely scrape my headers or y-pipe. I did swap out the rear isolaters in place of some rubber hose to drop the back a little more.
Just to give you an idea, I can stick about 2 1/2 fingers in between the fender and tire up front and 3 fingers out back.
Old Mar 30, 2005 | 08:24 PM
dws6's Avatar
I am curious too. TTT for ya.
Old May 15, 2005 | 03:42 AM
Aaron's 00 TA's Avatar
I put the DMS springs on the car along with some HD's:
The front dropped alot and the rears don't look like they dropped at all. I can almost get one finger in above the front p-side tire, and one complete finger above the d-side front. The p-side rear I can get 3 fingers in and the d-side I can get 4 fingers in. I thought the rear would of dropped more than this. Looks almost stock to me.
Old May 15, 2005 | 07:14 AM
n2oblkz's Avatar
I have DMS springs and love them. They ride great (nearly like stock) and have a great stance. I did cut my rear springs though because about the time that I bought mine, they had changed the spring rates and it made the car ride a little higher in the back than some of the other cars that I had personally seen. Here are some pics.
http://img212.exs.cx/gal.php?g=benscar9mx.jpg
Old May 15, 2005 | 12:38 PM
OneMeanZ's Avatar
Where can you get DMS springs?
Old May 15, 2005 | 01:15 PM
ChevyWeatherman's Avatar
master of the "jack"stand
The key to getting the right look with the DMS springs is removing the rear spring isolators. If you don't take them out, the front will look unproportionately slammed. I also used some rubber hose around the top of the rear springs. Here are some pics of my car, shocks are Koni DAs.
Old May 15, 2005 | 09:03 PM
Are those the rubber spacers? what kind of hose did you wrap around the spring? Got any pics?
onemeanZ- you have a PM, since i don't think they are a sponsor.
Old May 15, 2005 | 09:09 PM
ritz's Avatar
I'm thinking he used 5/8" heater hose. That seems to be the replacement of choice when people remove the rear isolators. Could be wrong though.
Old May 16, 2005 | 06:14 PM
Yes, I think that is the size I used. It was a very tight fit getting the hose on, I ended up greasing the spring and hose up to make it slide....
Old May 19, 2005 | 12:40 AM
MasterOfPuppets's Avatar
Sweet looking ride! I'm going with these springs for sure!
Old May 19, 2005 | 05:27 PM
Marc '99T/A's Avatar
Mine definately has the slammed look in front, and I couldn't stand how the back stood so much higher. I ended up cutting a half a coil out of the rears, and it helped a lot. Now, I like the look, but the front could be a little bit higher still. When I got my alignment, it helped the front look a little higher. I guess when it was dropped, the angle of the front tires caused them to sit higher up in the wheel well????? I dunno. But the alignment did help. Personally, I wouldn't recommend them. I'm tired of skimping on a few dollars here and there for a cheaper product, then regretting it later. Just my 2 cents. Good luck with your decision.
-Marc
