Need Help Asap-brakes
![Question](https://ls1tech.com/forums/images/icons/icon5.gif)
Just changed the pads Hawk HPS and the driver's side front wheel brakes lightly without applying the brakes. The pistons don't open up properly I guess. I redone it -installed the pads again and still the same problem.
The brake fluid level is under the max sign what is fine.
Brakes are fine, lightly I meant becouse the new pads.
Brake pads rub aganst the rotor on the driver's side front wheel, even without applying the brakes. The car brakes on it's own....
![EEK !!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_eek2.gif)
Hrmm, that's odd. Did you force the pistons all the way back inside the caliper when you re-installed the pads? Also are you sure everything is perfectly seated/installed... specifically the rotor? Did you change rotors at the same time? If not, did you check to see if the pads are the same (proper) thickness as the others? If you're sure the calipers are in the proper operating order... I've gotta ask if you've fully completed the Hawk break-in procedure?
The pads are going to touch the rotors, without applying the brakes. So when you are coasting, put it in neutral, and see if in fact it is braking, youll notice it. If you just keep rolling, and dont stop then they fine. If the brakes were "dragging" like you say, the rotors would turn RED hot in just a few miles.
Well they are not red hot only brakes slightly. The driver's side front brake brakes as it stated above and a wheel is HOT unlike the others. One of the piston does not go back ---> does not realese the pad (brakes)-------------->uneven wear on one pad.
I did reinstall the hole thing 3 times already.
What I was told the piston probably "rusted in" due to the shorter movement of the old pads.
Solution:
Insert the old pads put back the caliper apply the brakes.
Take appart the hole thing push back the pistons, old pads back, put back the caliper, apply brakes.
Repeat it several times- it suppused to cure the problem by fully moving in and out the pistons.
Well I give it a shot then I hope....
Solution:
My thoughts.
