anyone running a rod ended panhard rod?
You don't need these for the PHR. Good rod ends work well. Poly on one end and rod on the other is still a good solution for the PHR, though it will still have some slack in it. Poly/poly is still not too bad and way better than the rubber/rubber of the factory piece.
These rubber beauties, when combined with rod ends, are just right for the "LCA". Should be able to make a set of LCA's for about $160.
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
