What will bring back my steering response?
After I had the BMR K member installed replacing my slightly bent stock K member, the car just doesnt respond like it use to. What can I do to get it back?
I am doing SFCs very soon, I'm sure they will help a tiny bit. What about the STB and a larger sway bar?
Thanks
Brandon
Thanks
Brandon
Just changing the k-member shouldn't have any effect on steering response. It's a structural member and doesn't directly contribute to the handling of the car.
But... the car had to be re-aligned as a result of changing the k-member.
The new alignment must be different than the old one. Who aligned it and did they give you the specs they set it to?
I did have it aligned and he did not give me the specs. What are the specs it should be?
With new stiffer bilstein shocks and 275/35/18 tires you would think it would be even more touchy than whehn it had the decarb shocks and 275/40/17 tires. But that is definately not the case.
http://www.frrax.com/rrforum/
The admin is Trackbird, these guys really know whats up, and will be able to answer any sort of handling question you throw at them
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
