Relocation brackets, what hole....
![Question](https://ls1tech.com/forums/images/icons/icon5.gif)
I need to know what hole to use on the relocation brackets. I didnt lower the car the normal way, i did it with the added speaker box and amp and what ever other junk i have back there. I do need the brackets since the car sits 1" lower with that stuff and the end of the controll arms(on the rear) are higher than the front mounting point. Next thing i do know that you want to pick the hole that will make them level to the ground, MY QUESTION REALL IS WOULD IT MAKE A DIFFERENCE TO TRACTION IF IT WAS A LITTLE LOWER THAN THE FRONT OR DO THE BEST RESULTS COME WITH A CONTROLL ARM THAT IS LEVEL... thanx
