Do I need to turn my new iRotors ?
![Question](https://ls1tech.com/forums/images/icons/icon5.gif)
Just recieved my new iRotors, w/zinc plating. They look real nice. I looked up iRotors web site but could'nt find any info on using the rotors right out of the box. yes or no - do they need to be turned ? Thanks
![Driving](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_driving3.gif)
You can't turn drilled rotors. You can have a machine shop grind them, but there is no reason to grind new rotors. Actually, a good rotor will be ground form the manufacturer (it will have a visible grinding pattern that runs in "2 arcs" (different directions). If they can't build them "straight", I'd buy something else. So, install them straight out of the box.
Have fun!
Have fun!
Trackbird. They are ground from the factory before the zinc goes on.
AGL. No need to mess with em, just bolt em on! If your old rear rotors give you flack about coming off, just get a rubber mallet and give em some really good whacks. (Dont knock it off the stands!)
Thanks for responding. For future referance - do shops that turn rotors also grind them ?. What pads work good with these rotors ( minimal dust ).
Turning is done on a brake lathe, it cuts the rotor like a record (one cut that spirals out from the center, using a single cutting blade per side). Grinding is done by using a multi bladed cutter that spins across the surface of the disk and leaves a "swirl" pattern (like your new rotors show). Turning rotors is a way to fix warped ones or resurface a rotor for fresh pads. It's better than nothing... Grinding assures parallel surfaces and leaves a "non-directional" finish (this is important).
When you turn a rotor, you cut a pattern in it like a record. This can act as a "screw" to pull the pads into the rotor (or push them away, depending on the direction of the rotors rotation). So, you are supposed to sand a rotor with a sanding attachment (it is done several ways) to remove the spiral finish. A rotor that has been ground will not have this problem.
hey all, I have a question about my rotors. I have EBC rotors, and they kind of vibrate. do you know if these can be turned. I know that brake lathe will not help for drilled rotors. I was told that flywheel grinder WILL do it. however, I have been calling hundreds of shops, and no one has such a grinder. CAN YOU HELP ME. I don't know where I can get that fixed...
![Sad](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_sad.gif)
Just recieved my new iRotors, w/zinc plating. They look real nice. I looked up iRotors web site but could'nt find any info on using the rotors right out of the box. yes or no - do they need to be turned ? Thanks ![Driving](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_driving3.gif)
