E-brake
Old Apr 22, 2005 | 06:34 PM
peterock98's Avatar
Default E-brake
Does any one know the part # for that little rubber peice on the backing plate for the E-brake .
Old Apr 22, 2005 | 07:02 PM
boondiggys's Avatar
ssame subject, sorta...lever that actuactes the parking brake doesnt do anything...drum assembly put on by a shop so i dont know why/// any one??
Old Apr 22, 2005 | 09:48 PM
peterock98's Avatar
Mine is making a noise.
Old Apr 22, 2005 | 10:24 PM
ACW's Avatar
ACW
If it's not doing anything, maybe the cable just isn't connected?
Peterock98, perhaps what you're asking about is the rectangular Floor Panel Deadener, part number 10249163?
Old Apr 23, 2005 | 01:49 AM
VIP1's Avatar
Copy & Paste Moderator
I think he means the (1" X 2") rubber boot on the backing plate of the rear brake assemble where the cable enters. Mine's ripped too.
Old Apr 23, 2005 | 10:50 AM
ACW's Avatar
ACW
Ahh, okay. Looks like that isn't available by itself, but is available as part of the whole rear parking brake assembly:
98-02 with NW9 traction control:
LH: 10434794
RH: 10434795
98-02 without traction control:
LH: 10434796
RH: 10434797
Or the service kit (98-02 without positraction) (one needed for each side, LH and RH): 12454994
Old Apr 23, 2005 | 07:45 PM
peterock98's Avatar
Thanks I got one today from a parted out car.I got lucky 20 bucks for the left backing plate.
Old Apr 26, 2005 | 07:07 PM
boondiggys's Avatar
no no i have the cable off and im moving it by hand....it has free range of motion no tension!!! whats up?!?
Old Apr 27, 2005 | 08:23 AM
peterock98's Avatar
Disconnect the e -brake cable.Take all apart( caliper and rotor) .Pull off the shoe and the adjuster and the peice that's opposite the adjuster.Pull out the peice(It's j shaped) that hooks up the the E -brake cable.Then put it back in make sure it's all in the way.Check it by pulling it put adjuster and the peice that's opposite the adjuster,then put the shoe on.Then caliper and rotor.
Old Apr 27, 2005 | 08:24 AM
peterock98's Avatar
LH: 10434794
RH: 10434795
LH: 10434796
RH: 10434797
Thanks for the part #'s
Old Apr 28, 2005 | 07:52 PM
boondiggys's Avatar
cuz its really bothering me boths sides are not working....ill let you know how it all turns out...thanks!!
Old Apr 29, 2005 | 06:26 AM
peterock98's Avatar
Ok good luck.
Old Jul 9, 2005 | 01:55 AM
boondiggys's Avatar
ok pete , got the rotor off... im stuck on the shoe...it wont come off....i dont wanna force it, any secrets??
Old Jul 9, 2005 | 03:50 PM
ACW's Avatar
ACW
"Park Brake Shoe Replacement
Removal Procedure
1. Remove the brake rotor.
2. Rotate the parking brake adjusting nut until the adjuster is in closed (fully) seated position.
3. Remove the parking brake shoe assembly."
Perhaps Step 2 is the issue?
Old Jul 10, 2005 | 06:34 PM
02WS6Bird's Avatar
Removal Procedure
Anyone have a pic of ther Parking brake adjusting nut, or could you tell me where it is located and how to close it fully? Is it on the bottom?
Old Jul 10, 2005 | 07:00 PM
02WS6Bird's Avatar
Anyone?
Old Jul 10, 2005 | 08:02 PM
boondiggys's Avatar
yes adjuster is closed...which way should i pull to take it off??
Old Jul 22, 2005 | 12:53 AM
boondiggys's Avatar
update...got the brake functioning...when i twist the adjuster, nothing seems to happen. is the operation internal?
Old Jul 22, 2005 | 12:54 AM
boondiggys's Avatar
update...got the brake functioning...when i twist the adjuster, nothing seems to happen. seems like the operation is internal..??
Old Sep 1, 2005 | 12:56 PM
boondiggys's Avatar
the adjuster had stripped out causing the tension to not be applicable....got a new adjuster and all is well....i apreciated everyones help..
