Manual steering rack
for the weight savings. I have heard of guys using a Pinto rack, but I am not
sure if it was for an F-body.
F.J. Smith makes a rack kit too using a Wilwood unit.
The you will need to make tierod sleeves and buy heim joints $50.00. You will need a bumpsteer kit which will run somewhere around $150.00. After you buy all the parts you need a way to mount the rack to the k-member.
The rack I sell comes with all of the above .
<--another satisfied customer!!
The stocker is like a 12:1 ratio, whereas the Pinto is more like an 18:1. With skinnies on the front, the car turns VERY easy. If you're running full-size wheels, you don't want a manual rack.
