ABS Delete / Line Lock Install
Most intelligent post of the day.
I've never owned a vehicle with abs, it's always cause more problems then good.
My car hasn't had ABS for years, lol
Very simple, steve sends you absolutly EVERYTHING that you need to do it right. All the way down to the wiring.
Thanks for the kind words. To reiterate, the kit can be ordered as a complete kit like your kit was. It is also offered in a variety of configurations for different applications...i.e. if you already have a double flaring kit...or purchased at an earlier time an SLP line lock solenoid as well as our as b001 solenoids.
Nova5,
I certainly do not want to argue your points of retaining ABS as it does have validity to it. Many consider F-bodies as a performance race car, not an everyday grocery, take your kids to school, all season driving vehicle. For the folks who use the car in this particular application, I wouldn’t advise removing ABS, changing to a light-weight k-member etc…these are all off-road modifications and race-oriented not intended for General Street DOT or safety approved use.
Removing ABS has no effect on normal driving. If you've never felt your pedal pulse, then you have NEVER used your ABS system. In this case, with the use of our proportioning valve, your car would drive just the same! The use of the proportioning valve is used to adjust your rear/front bias pressures to ensure correct braking performance…under hard braking conditions your ABS modulator and computer attempted to adjust this for you while reading specific data from its gear sensor using hall-effect gear tooth technology. Like mentioned, if you have never felt your brake pedal pulse, you've never used your ABS features.
Using a proportioning valve is an important adjustment feature as with different tire combinations adjustments ARE necessary. Without the valve, rear brake pressure will be nearly the same as the fronts creating the rear to ‘squat’ on braking and locking them up putting the car into a situation where the rear can spin out on you. (Some may relate this to going into a parking lot, applying the emergency brake and making doughnuts.)
For the race-oriented folks, removing ABS has MANY benefits i.e. removing ~10-12lbs of weight from the front end, opening up the engine area for increased air flow, some supercharger/turbo applications, different front/rear tire combinations...in these circumstances, the benefits are substantial or actually necessary. ABS has very little use and is actually a hindrance when it comes to road racing as well as drag racing.
It all depends on how advanced you prefer to go with your vehicle.
Steve
check this out...http://www.mucda.mb.ca/aboutabs.htm, a study says its 65% more likely to be in a fatal car crash with ABS than without....think about that one
"Anti-lock Braking systems were developed to reduce skidding and maintain steering control when brakes are used in an emergency situation.
However, cars with anti-lock brakes are up to 65% more likely to be in fatal crashes than cars without them, says a new US study. It appears that the problem isn't with the technology, it's poor driving habits and lack of driver awareness on how the brakes operate. Driver who rely on technology instead of better driving habits to improve safety are driving down a dangerous road.
Since much of the problem stems from lack of awareness of how to use the brakes, education is needed."
Most of these accidents are single-car, since the ABS lets the driver retain steering control. The problem with that is that the driver will avoid whatever was in his path but drive right off the road into a tree, phone pole, guard rail, ditch etc. But it's the ignorant, panicky, unskilled driver (who's usually too tired to drive anyway). It isn't the fault of the ABS.
