Decided Shocks...What Else?
PHR and LCAs probably wouldn't hurt for traction purposes. Swaybars would make a nice difference in the corners. I don't know that any of them besides shocks will actually improve the ride itself.
Also, would you recommend adjustable lca's or not if the car isn't planned to be dragged that often if at all? Thanks!
My bars are 35/22 hollow, not 21. I also have 4 different style of Panhard bars which can be shipped with a set of, or individual swaybars too. I'm not a believer in mixing and matching ends. If you want bushings, run bushings. If you want rod-ends, run rod-ends. The setup is only as good as it's weakest link....
I don't believe that LCA brackets are necessary (I don't have them), but if you do want them they are readily available as well....
Torque arm is also not what I'd term necessary. But you might want one. You need to start with the shocks and bars first. They will make the biggest handling differences of all. Spring certainly help, and it makes sense to do those with the shock install. And when you lower, a PHB is something you want to have in order to re-center your axle.
In short, the springs, shocks, bars, and PHB are more on top of the list than are LCA brackets and a torque arm IMHO.
