SLP Panhard Rod
SLP Panhard Rod
http://www.slponline.com/view_produc...01&BIG=70401-1
I can't tell from the picture. Does anyone know if this is a tubular or a "stock" style rod?
Yeah, I've seen those boxed arms before. I would just weld some plate onto my own before I wasted time buying one. The problem is the eurothane bushings. I want to use rubber bushings. I won't use rod ends either because they transfer way too much vibration into the body.
At the very least, get poly. The rubber just deflects too much.
I know what you mean. It is sometimes refered to as NVH which stands for:
Noise
Vibration
Harshness
Rod-ended LCA's are known to transmit NVH in the cabin, but due to the minimal loads on the PHR under normal conditions, they just don't contribute to the cabin noise.
Noise
Vibration
Harshness
