Granatelli Adj. PHR
![Unhappy](https://ls1tech.com/forums/images/icons/icon9.gif)
Well, I installed my new adjustable panhard rod from Granatelli, and now, I have a clunking sound coming from my rear whenever I hit any bumps. The instructions say I was supposed to just re-use my stock bolts from the factory bar, but they wouldn't fit through the new one. I had to go to a bolt store and get some to fit. Anyways, this thing didn't come with any bushings; either rubber or poly. Was my shipment missing anything, or is that just how it is supposed to be?
er umm... you got the rod-ended bar. because theres no energy absorbing material like rubber or poly in there, rod-eded pieces tend to cause more noise. Also, not having the right bolts in there or not having them torqued properly or not having the adjuster tight might add to the noise.
