I need to lower my front end about 1" or so
What should I do? The back is fine, removed the isolators, but the front needs to come down. This is on a 2002 Z28 and I need something for dragstrip/ street use. No stiff *** lowering springs please. I'm thinking of cutting the front coils down but not sure if my goals can be reached that way?
Originally Posted by michelinss
i cut my springs no problems lowerd it about 2inches going to get some new pics so you can see it better
I wouldn't lower more than 3/4" through cutting the front springs. As you lower, you reduce your suspension travel. With reduced travel, you need stiffer springs to compensate. With a 2" drop on cut factory springs your rate is about the same as the Eibach Sportline but with a lower ride height. That is just not good.
If 3/4 or so will do it for you, then you can cut the spring without taking it off the car. Better bumpstops would help the travel and ride as well, but require a teardown to install.
Better shocks will definetly help all around. Ride will be better, will be less likely to bottom and handle better.
