Guys with Baer, I need your help bad!!
So i installed my kit, and now for some weird reason, the backside of the rotor barely touches the inner control arm or whatever that lower arm is that mounts the sway bar. Why on earth is it doing this?? I am pretty pissed off at baer right now because they didnt send me the caliper mounting bolts in the kit either, had to go find some at the hardware store. any1 know why it would do this?
Any1 else have this problem? It does it at like 3/4 turn to the left only...is there anything i could adjust to fix it?
EDIT, its almost like the camber is to positive, cause pad wear is uneven also
Restricted User
check this https://ls1tech.com/forums/suspension-brakes/314622-corvette-upgrade-baer-gt-lca-clearance.html
good luck Dale
