Two Options, Which Would You Recommend?
Option 1: BMR springs all around, Bilstein HD shocks all around
Option 2: Stock springs all around, Koni SAs on the lower perch up front, Bilstein HDs in the rear w/ isolator removed
Which will offer the best all around ride as far as ride quality, handling, and ride height go? The stock springs with Koni SAs is a little more expensive. I've already got the Bilstein shocks all around so no cost there. Front Konis we're looking at $500. I could sell the Pro Kit on the car now as well as the BMR springs and the front Bilsteins and make back most of that $500. Going with the BMRs all around I'd almost break even also as I already own the HDs, I could sell the Pro Kit, and I got the full set of BMRs for a good price as I already owned the rears from a previous setup.
Nice stance, however. And ride quality is very close to OEM.
If you're seriously looking for a significant step up in handling, I don't think the BMR's will take you there. They are good quality, though, and they're at a good price.
If your shocks are in good shape, you might consider the Prokit springs and use a spacer in the rear spring to add height and rate.
Seriously, I have 550/170lb springs and Koni's and the ride is fine to me. It's my daily driver and passengers have never complained about the ride other than it is capable of tossing you around in the corners or under braking.
Here's my stance:http://img.photobucket.com/albums/v3...wcalipers1.jpg
http://img.photobucket.com/albums/v3...SideView2b.jpg
http://img.photobucket.com/albums/v3...wCalipers3.jpg
I can raise or lower each end to my hearts content.
The BMR springs are stiffer than you think and I'm not sure how well they will work with those shocks (I'm not saying you can't run them together, just that I'm not sure if it's enough damping for that rate. Since I have no first hand experience with that combo, I'll have to error on the side of caution).
I still say go with the shocks all around. That's what I should have done... but I found a deal on H&R Springs I just couldn't pass up... =).
