Non-Adjustable Torque-Arm??????
Old Jun 14, 2005 | 06:06 PM
NexGen's Avatar
Default Non-Adjustable Torque-Arm??????
There is a shop in Austin that has a non adjustable, after market torque-arm. They say it is stronger than a stock torque-arm, but what i want to know is....will it give me a better 60ft time? Also, how strong will it actually be in comparison to a stock torque-arm or an adjustable torque-arm?
Thanks in advance
Old Jun 14, 2005 | 06:33 PM
hpjunky98's Avatar
it will be alot stronger. the stocker is a peice of stamped steel, the aftermarket ones are tubular. you dont need an adj TA, its just better if you know how to tune it correctly.
Old Jun 14, 2005 | 06:51 PM
lilstephsls1's Avatar
CT Hotness
my stock torque arm broke.. piece of crap.
Old Jun 14, 2005 | 07:15 PM
Matt D's Avatar
Retired Street Racer
the non adjustables are good for mild setups. they are pre set to a -2 pinion angle. anything is better than the stock one.
Old Jun 14, 2005 | 08:06 PM
NexGen's Avatar
so it should be optimal for a 370-400 hp car???
Old Jun 15, 2005 | 09:06 PM
NexGen's Avatar
anyone?
Old Jun 16, 2005 | 03:02 AM
DONAIMIAN's Avatar
Yes it should. But then again cheese did do that 7.0 in the 1/8th on a stocker. Its up to you. You will see a gain, but im the type of person that if I do it, im gona do it once and for all and get the adjustable one the first time.
Old Jun 16, 2005 | 05:23 PM
NexGen's Avatar
I hear that Donanay. I have already broke one on the 12 bolt. And the one I have now, I know it is bent.
