ABS kicking in?
My mother had a 98 Lumina when it was new, like in 2001 we knew we were going to get her a new minivan, and the Lumina started acting up... She would complain that the break pedal did nothing sometimes...
So I replaced the pads and rotors (they were not too bad, but I replaced them anyways)... Its fine for a few days and then the problem seems to only get worse... I take it on a test drive, it is acting fine so I decide to test it at a higher speed... I take it down my dirt road and hit 90, start getting on the brakes and nothing happens... now there is a canal not to far away. I manage to stop the car and decide it had to be something with the ABS, we replaced everything in the braking system (except master cylinder) and it still did it.
Finally we replace the master cylinder and it goes away.
The three pieces weighed 14lbs 9 ounces on a calibrated shipping scale. You can also remove the associated wiring which I’m sure will weigh another 2 lbs.
Our ABS delete kits which are available in a variety of styles to suit many needs. They all come with the necessary proportioning valve to retain correct bias between front/rear wheels.
Steve
ABS is very troublesome on the race track albeit drag or road race.
