I Need Pics of Brake Ducts
I'm trying to get as many pics of front brake cooling ducts as I can. If you have any pictures, I would sure appreciate them. If it is from a different style of car, but well done, post those too. I could use good ideas.
I'm working on an idea that uses metal tubing for all the rigid parts and then silicone for the flex parts. I want to put together something that is more durable than the all flex designs I've seen.
Thanks,
Jason
Thanks,
Jason
I got some responses on the FRRAX forum. I also decided to post all the links and pics that I already had. Go there to check them out.
http://frrax.com/rrforum/index.php?a...=0&#entry50598
the real problem seems to be lack of space in the wheel well, esp at lock to lock.
www.severnmotorsports.com/index.html
not a promo, but has a kit ready to go
The real problem is that the whole setup hangs so low that it can get torn up pretty easily. I am trying to think up a way to make it more durable.
PS, the Severn's are way over priced for the rotor ducts.
