quick n easy question
Old Jul 4, 2005 | 05:08 PM
Jpr5690's Avatar
Default quick n easy question
when using a c clamp to push the pistions back in to the caliper for new pads do you need to open the bleeder valve.. i was told locally that if i didnt open the valve it could damage the pistons ...
Old Jul 5, 2005 | 06:15 PM
Jpr5690's Avatar
guess its not so quick n easy??? anyone wanna take a swing a this one...
Old Jul 5, 2005 | 06:46 PM
99hugcam's Avatar
As long as you do it slowly, it will be fine. The fluid will be forced back through the hydraulic system. If you are compressing dual piston calipers, use something to lay across the pistons to compress them at the same time, like an old brake pad etc. Hope this helps.
Old Jul 6, 2005 | 08:03 PM
8-Pack's Avatar
You want to take the cover off of the brake fluid reservoir and put a rag around it to catch any fluid that overflows, thats the way I have always done it.
Old Jul 7, 2005 | 12:00 PM
Jpr5690's Avatar
ok so no bleeding nessary?
Old Jul 7, 2005 | 05:51 PM
8-Pack's Avatar
As long as you keep the calipers attached to the brake lines, no bleeding is needed.
Old Jul 7, 2005 | 06:14 PM
Jpr5690's Avatar
good deal sounds all too easy.... and the bolts get torqued to 75 lbs ?????
Old Jul 8, 2005 | 08:30 PM
8-Pack's Avatar
The caliper frame bolts get tq'ed to 74 ft-lb and the caliper to frame bolts get tq'ed to 23 ft-lb
Old Jul 9, 2005 | 02:24 AM
Jpr5690's Avatar
good deal
