Rear Rotor Do not want to come off????
![Talking](https://ls1tech.com/forums/images/icons/icon10.gif)
My Rear Rotors do not want to come off???? I followed the manual and they will still not come off. I also tried a rubber hammer and they will not come off...I sprayed them with WD-40 and will try again after supper. The parking brake is off. Should the car be in Netural. That should not make a difference.
Is there a trick to get them off when they do not want to?
Bill
Bill
![Engarde](https://ls1tech.com/forums/images/smilies3/engarde.gif)
![Driving](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_driving3.gif)
![Chug! Chug! Chug!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_chug.gif)
Just takes time Bill ,there is no trick you have not tried, they will come off . Work them with the rubber mallet some more going around them . Dont go bustin at them either all mad ,cause your gonna hurt the axle or yourself
Check the the park brake again , does it lock the wheels when you put it on ? then move free when its off?are the little star washer things still holding the rotor on ? With the mod list you have I think you know what your doing , just step back and take your time . Good luck
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
taking it off, i used a ballpeen hammer to the center section of the rotor, took a little play but came off
In order to get them back on you can close/collapse somewhat of the parking brake. made it easier, but still needed the ballpeen hammer for that passenger side
![Icon Confused](https://ls1tech.com/forums/images/smilies2/icon_confused.gif)
If you have a large brass hammer, use it! We actually have a home-made brass hammer that has about a 5lb head on it. Works wonders on those stuck rotors. Make sure you put some anti-sieze on the back of those rotors once you get them off. Just make sure not to get any anti-sieze on the e-brake shoes.
