Intalling lowering springs.
Old Jul 13, 2005 | 11:55 AM
ninety9ta's Avatar
Default Intalling lowering springs.
How much much would it be on average for a shop to charge to install some DMS lowering spring? Thanks.
Old Jul 13, 2005 | 03:15 PM
2_wacko's Avatar
A shop is going to ripp you off. Try looking for some one who has done this kind of work before, and have them do it. Good luck man.
Old Jul 14, 2005 | 03:18 AM
joblo1978's Avatar
Have even better luck getting the bolt off of the passenger side front shock to disassemble. I had to destroy my shock to get it off. For some reason on these cars water collects in there and rusts the **** out of it. Had to cut the bolt off and slice through the shaft to get it off. This was after lots and lots of break free and air tools. Just be prepared when you do the install however you do it and have some new shocks ready.
I'm not the only one.
Old Jul 15, 2005 | 01:15 AM
95camaroz28's Avatar
least im not the only one
Old Jul 15, 2005 | 03:02 AM
DONAIMIAN's Avatar
atleast do the back ones yourself, If you cant find anyone to help you with the fronts, take it to a shop, they should be able to cut you some slack since the rears are already done.
Old Jul 15, 2005 | 03:20 AM
Phoenixta99's Avatar
I also need some info on the front shocks.... and from what i hear, that rust is no understatement. My friend did his by himself, but eh said it was about an 8 hour project (alone). thankfully, he should be helping me.
PS. Stangkiller, put some pics of yr car up man! I wanna see that color!
Old Jul 15, 2005 | 09:29 AM
smokin98's Avatar
I had the same problem, ended up being a weekend project...
Old Jul 15, 2005 | 11:20 AM
GuitsBoy's Avatar
I did my first fourth gen with a pair of autozone spring compressors in a weekend. Second car took about 8 hours. Now I bet I could do them in 4 or less.
Old Jul 15, 2005 | 11:47 AM
superchannelkev's Avatar
did my car twice.. once for the springs and then again when i got my HD's no issues and no spring compressors... max. 4hrs first time and second time it was only the fronts so even less... going to be switching springs soon soo we'll see how long it takes this time..
Old Jul 15, 2005 | 03:02 PM
Uno99's Avatar
I have been quoted 4-5 hrs at 79$/hr at Carx and Midas. Most place will qoute 4-5 hour for all four. Then just find a shop you trust and hope the shop rate is reasonable. I found a shop here that does work for 55$/hr Xtreme motorsports in Appleton Wi
Old Jul 16, 2005 | 01:02 AM
joblo1978's Avatar
The rears are easier to do if your doing springs only, alot easier. If your doing the shocks on the rear also, that is a pain the the *** because you have to lift up the carpet in the rear. It's doable with a few tools and you can do it in your driveway. You don't need as many tools for the rear but it would save alot of money to do the rear springs and shocks yourself if you worried about doing the fronts and wanted a pro to do them. The front is a bit more complicated. On the driver front you need to unbolt the Master Cylinder and slide the ABS control module forward to get to the Torx bolts. On the passenger front you may not be able to salvage the stock shock from terrible rusting on the top nut. And just putting the assembly back in the car can be a real pain in the *** too! I'm not telling you that you can't do it because I spent about 5 hrs. installing my ground controls yesterday. (First install took 10 hrs. almost a year ago when I did my prokit and HD's) The longest part of the install for was adjusting the sleeves and getting the car to sit how I wanted which you don't do with regular springs. Here's some pics of the install.
Today my knuckles, forearms, and thighs are sore. It's worth it though, and I spent 25 dollars in time at the shop on Ft. Carson. Military guys have access to lifts, paint bays, and any tool you could think of for a few bucks an hour.
Old Jul 16, 2005 | 07:48 AM
01 Red WS6's Avatar
I took my car to a shop to have the springs installed. For me it was cheaper in the long run. It would have taken me all day and it only took the shop about 45 minutes. I paid $150 and was happy with the work
