First Suspension mods
thanks
Are those any good? im gonna buy some subframe connectors from teh same company if they are.
First, the panhard rod isn't adjustable so if you change your car's ride height your rear end won't be centered under the car.
If you use lower control arms with poly bushings on both ends you increase suspension bind and you will actually have less traction powering out of turns than you have now with rubber suspensions.
I suggest an adjustable PHB and LCAs with at least one articulating end (rod ends)
