How can I reduce brake fade?
I need to reduce brake fade. Any suggestions on pad/ rotors / lines. The shutdown lane at my local drag strip is very short. I find my brakes start to fade almost instantly when I brake heavily in the shut down lane.
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
Try bleeding the brakes, or if you want, you can go ahead and do a fluid change and replace it with ATE super blue. Also a good set of pads would help, are you still on the stockers?
Yup, have you considered carbotech pads, theyre growing in popularity. Also I think LG motorsports should have ATE superblue in stock. Or you can check a local shop to see if they carry it.
ATE Super Blue or TYP 200 (Same fluid, different color to make it easier to change) should be about 10 bucks a liter if I remember right. Carbotech pads I hear are pricey, but I've heard some excellent things about them. They're on my list for next.
Hawk HPS pads are a good start. Or, Carbotech has some compounds you may want to try (I forget which ones, I never look at the "street" pads on their list). I believe the Axxis pads they sell are similar to the Hawk HPS, but I'd call them and verify that (they are a hawk dealer too, so they'll tell you the truth).
Well, it'll probably help... but then again, Trackbird can fade Hawk HP+ pads in a 50 second autoX on a Wilwood brake kit... Then again we all know that he drives like the mail man in the movie Funny Farm.
Just remember that your mileage may vary.
![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
I have had fade issues on a 50 second autocross course to the point that I can't lock the brakes when I clear the timers at the end. This is with a 6 piston wilwood kit and HP+ pads. I doubt you'll do the things I do to brakes in that 50 seconds.....so, your results will very likely vary.
Originally Posted by trackbird
My rotors only turn purple (where they are not blue or orange
![Tongue](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_tongue.gif)
No really, you're an amazing driver Kevin... in those 50 seconds... half are spent forwards, the other half are spent sideways and/or backwards. ![Tongue](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_tongue.gif)
Oh no, I spend far more than half of them sideways or backwards.....it's more like 3/4 of them. I only go forward during that one point of each spin when I'm pointed that way....
Anyone know where I can find carbotech pads online? Any sponser carry them?
