Need help with weird vibration
Old Jul 25, 2005 | 03:21 PM
BGImportkiller's Avatar
Default Need help with weird vibration
I just installed my Spohn tunnel mount torque arm, and i set the angle to -2 and i double checked that. 1st off, it makes a huge difference and I am definitely glad i got it.
When under heavy acceleration or decel it feels fine. When under normal to light accel/constant speed between like 30-50mph the entire car vibrates slightly. It feel similar to the vibration I used to have with bad tie-rod ends and my old driveshaft at high speeds, but alot slower, obviously because I am going slower. Do I need to look at the angle again, maybe go a bit more toward 0 or could a bolt on it be loose? (I tightened them all real well, but maybe?) Or is it something else?
Any input is appreciated and thanks in advance.
Old Jul 25, 2005 | 03:29 PM
pimpmaro's Avatar
The torque arm and pinion angle settings are a bit out of my current realm of knowledge, but from what I understand, the more negative angles are for drag racing where launch and traction is ideal, while 0 is the best for U-joint wear. Just based on that, my assumption ( I know... I'm dangerous... heh) is that the pinion wants an angle closer to zero, hence the vibration. Hopefully someone who actually knows what they're talking about can come in and confirm that for me.
Old Jul 25, 2005 | 09:17 PM
Xtreme57's Avatar
i just got the same tq arm with the same problem - the shop set it to neg 3* and yes, there is a wicked vibration from 30mph that has me pretty worried
Old Jul 26, 2005 | 12:08 AM
pimpmaro's Avatar
neg 3* is probably a bit far.... I did some consulting this evening and the number I hear that's pretty decent is -1*. Also there's some sort of debate that continuing to decrease the pinion angle doesn't actually help launch at all. Take it as you will, but if it's iffy and I can increase the longevity of my u-joints... all while elminating vibration, I'll take that option.
Old Jul 26, 2005 | 03:16 AM
Xtreme57's Avatar
oh no that sounds much better. i'm bringin my car back tomorrow to get it fixed. How hard is it to adjust myself? I just got it and i really have no idea about that part of the car...
Old Jul 26, 2005 | 08:30 AM
Its not hard. Just a two nuts to lock it in place and then the actual adjustment shaft. Let me know if the vibration goes away after you have it adjusted.
Old Jul 26, 2005 | 08:34 AM
pimpmaro's Avatar
You need an angle finder though, and if I remember right, you also have to set the pinion angle according to the angle of the tailshaft of the transmission.
Old Jul 26, 2005 | 09:27 AM
Right, well sorry it was early. I was talking purely about the mechanical aspect. You have to use the angle finder on the driveshaft and on the mounting plate where the torque arm attaches to the rearend.
Old Jul 27, 2005 | 08:04 AM
Anyone else?
Old Jul 27, 2005 | 05:50 PM
Xtreme57's Avatar
how do you set the pinion angle??
Old Jul 27, 2005 | 10:02 PM
OldeSkool's Avatar
pinion angle has nothing to do with trans tailshaft on these cars... It just has to do with the angle between drive shaft and rear axle...
The red numbers are not what your protractor will read, but they are the numbers of the imaginary line through the driveline. Hope this helps.
Last edited by OldeSkool; Jul 27, 2005 at 10:11 PM. Reason: fixing picture link again
Old Aug 28, 2005 | 10:46 PM
SSnakekiller's Avatar
So did you guys ever get this solved? I am having vibration/shaking past 60mph. I can look over and my passenger seat and see it shaking. I have a BMR adj that i set to -2 or -3 and I am hoping that is what is causing it...
Old Aug 30, 2005 | 05:05 PM
Mr_president's Avatar
i have the same problem vib from 60 on but i orderd a new drive shaft will see if that helps the problem if not...... oooooooh weee
Old Sep 1, 2005 | 02:26 AM
Xtreme57's Avatar
nope the shop ASSURED me that neg 3* is the BEST and ULTIMATE position for this tq arm to be at, but instead, they are checking to see if it's my new lpe driveshaft, then the output shaft on my trans and then the ring and pinion gears....
Old Sep 1, 2005 | 06:44 AM
pimpmaro's Avatar
If they can't figure it out, tell them to try re-setting the pinion angle to 0 or neg 1
Old Sep 1, 2005 | 12:16 PM
I have mine at negative 2 for sure, I have checked it several times. I still get some vibrations at highway speeds, but it got better. I don't know how to totally solve it yet.
Old Sep 1, 2005 | 08:51 PM
Guys have any of you installed relocation brackets? Check your rear end to see if it is square, meaning that...each wheel is centered in the wheel well.
I asked BMR about my vibration problem and I told them that after I did the relocation brackets (exactly as instructed), my rear end is now out of square, it is forward about an inch on the left side and back about an inch on the right side.
Well, I asked them if I needed adjustable LCA's to fix the prob and they said that the adjustable LCA's should fix the vibration problem, and will of course set the rear end back to its centered position.
Old Sep 6, 2005 | 06:45 PM
Xtreme57's Avatar
nope, no relocation brackets - i just got my trans checkout, and no problems there either. So if it's not the pinion angle, not the trans, not the driveshaft, that leaves the rearend...
i dunno if it's related, but when viewed from the rear, the right side of the car is sitting ALOT lower than the left. the shop replaced by ball joints (not sure if thats related), but just thought it might be a symptom, only b/c i'm running out of parts to replace.......
