Thumping Noise!!(experts Needed)
Old Jul 28, 2005 | 02:59 PM
turbols1_05's Avatar
Default Thumping Noise!!(experts Needed)
I have a 98 Z-28, A4,FRA,Lid,EGR MOD etc stock suspension stock rear end
Took it to the track 6 months ago, and ran it once. After the run I heard this
thumping sound coming from the rear. Its really noticeable in first gear when
I'm at a stop light. It will thump through 1st gear then it stop in 2nd. Also,
uphill its really noticeable. Also, when I hit a bump in the road I can feel the
back wheels jump just alittle.I have ok tires but I spin really bad off the line, it
catches though. Tranny shifts good from 1st to OD, its just that D#@$
Thumping.Question: What does this sound like?? (wheel hop, torque arms,
upper lower control arms, rear end shot GOD NO, or something else)
Old Jul 28, 2005 | 08:00 PM
ss02Camaro's Avatar
Default Have you looked at it?
Have you checked under the car? ie driveshaft bolts, yoke in diff, panhard bar bolts, shocks bolts etc? Anything loose or broke? Have you ever changed your rear end fluid? How many miles do you have?
Old Jul 29, 2005 | 01:07 AM
FIREHAWK #07's Avatar
check what he said..... i had a thump also..... it was the bushings on the LCA's.....
Old Jul 29, 2005 | 07:48 AM
CATCH ME's Avatar
my thump was a broken T/A mount on the tranny
Old Jul 29, 2005 | 08:14 AM
hambone138's Avatar
yeah its probably the transmission mount i just preplaced mine, its super easy. its about 60 bucks at the dealer but i think i got a discount. you will need a jack to lift up the transmission a bit though.
Old Jul 29, 2005 | 10:56 AM
if its the trans. mount just get a poly. one.... they are cheaper than the dealer and last way longer..... part # 47-7-1604 at http://thunderracing.com/catalog/?ac...&vid=3&pcid=92
Old Jul 29, 2005 | 11:45 PM
I have 115,00 on the car. A friend said its the torque arm. The sound is more like a popping sound than thumping /Almost like popcorn.
Old Jul 29, 2005 | 11:47 PM
Oh ok T/A means torque arm sorry!!
Old Jul 30, 2005 | 02:41 PM
SSblack98's Avatar
Definitely could be the torque arm mount. I have a stock torque arm mount with an almost new poly bushing already installed in it if you are interested we could work something out. Helps reduce wheel hop a good bit.
Old Jul 30, 2005 | 02:42 PM
SSblack98's Avatar
**** I forgot you have an A4 and mine is for a 6spd, I don't know if it would fit...
