C5 Calipers on a SS?
Old Aug 3, 2005 | 07:37 AM
CHRISS's Avatar
Default C5 Calipers on a SS?
Will the C5 calipers fit on my SS? if so, do they mount on just like my stock ones, or do i need a special bracket?
Thanks,
Chris
Old Aug 3, 2005 | 07:40 AM
TXAgZ28's Avatar
Do a search on this topic and you'll find the same question asked every day.
You need different brackets.
Old Aug 3, 2005 | 08:43 AM
trackbird's Avatar
I think he's wanting to use the C5 calipers on his stock LS1 brakes. If so, they don't fit properly, but if you do some grinding, you can get them on there. To use the C5 rotor and caliper and pads, etc, you'll need a conversion kit.
Old Aug 3, 2005 | 09:00 AM
CHRISS's Avatar
Grinding of the brakets?
do i need a conversion kit if i keep the stock rotors with the C5 calipers?
Old Aug 3, 2005 | 12:45 PM
trackbird's Avatar
You have to grind on the reinforcing ribs on the calipers in 2 places to get them to bolt to the F-body brackets.
If you keep the stock rotors, all you need to do is a bit of grinding on the caliper (which I'm personally not a fan of, but many have done it).
Old Aug 3, 2005 | 02:17 PM
Mtnm2's Avatar
Very odd my bolted right on
Old Aug 3, 2005 | 04:31 PM
CHRISS's Avatar
Mtnm2,
what you are saying is that i can buy a complete C5 caliper and install it as i would the stock F-body caliper?
I've searched and read previous threads, only to find contradicting info. its confusing.
Thanks
Chris
Old Aug 3, 2005 | 08:16 PM
trackbird's Avatar
Mtnm2,
I've gone back and read previous posts and it is very confusing.
Thanks
Chris
Basically, that's what he's saying.
Old Aug 3, 2005 | 09:25 PM
01 Red WS6's Avatar
I was always under the impression that they would bolt right in... the only difference was the pistons on the corvette calipars were smaller....
Do all corvette calipars have the corvette lettering?
Old Aug 3, 2005 | 10:01 PM
WILWAXU's Avatar
I bolted a set of Corvette ZO6 calipers straight on my car. No grinding needed. They are exactly like regular vette calipers, just powdercoated red
Old Aug 4, 2005 | 05:13 AM
makoshark's Avatar
They bolt right on guys. There is no grinding done if your just installing the C5 caliper only. They bolt right to the LS1 brackets. I`ve done it to my car as well, so I know.
Old Aug 4, 2005 | 08:32 AM
01 Red WS6's Avatar
ok now do the regular vette calipars have the corvette lettering on them? I want to get a set and powder coat them a different color than red so I really don't want the ZO6 calipars
Old Aug 4, 2005 | 09:07 AM
trackbird's Avatar
Yes they do. However, I somehow have come into posession of a set that have no lettering on them and I can't figure out where they originally came from (they are just black, no letters, on them and don't look to have been ground off and painted or anything like that).
Old Aug 5, 2005 | 01:36 AM
RpSS4844's Avatar
Do part stores sell reman calipers, if so this maybe where your calipers came from. When i got my calipers powdercoated, i went and bought two brand new calipers from advance and they work as well as the originals.
Old Aug 5, 2005 | 03:37 PM
Shadow's SS's Avatar
Hmm how much does a set of zo6 callipers cost and whats the advantage? Im still a newbie when it comes to mecanics I can replace anything one for one but I have always been able to do that with anything I just dont know whats better thats all
Old Aug 5, 2005 | 07:28 PM
01 Red WS6's Avatar
For a set of Z06 calipars you are looking at $350+
Old Aug 6, 2005 | 06:29 PM
76LS1BIRD's Avatar
Restricted User
95$ each @ SDPC
http://www.sdpc2000.com/catalog/875/...Components.htm
Dale
Old Aug 6, 2005 | 07:06 PM
01 Red WS6's Avatar
$95x4=$380 I know the backs are the same as ours but I meant for all 4
You could just get 2 and yes it would be cheaper since the backs are the same
Old Aug 8, 2005 | 10:37 PM
Not trying to steal this thread but how much better are the c5's callipers? I mean the car is lighter than the f-bodys so the same callipers on eather car would have diffrent stoping rates because of the weight. So are they really worth the money? Or should I go for an aftermarket manufacture
Old Aug 8, 2005 | 11:24 PM
pimpmaro's Avatar
There's a good bit of info on the C5 calipers in the brake sticky. Plus TONS of threads on the subject.
