low trac and pulseing brakes
Hello! I have a almost stock ws6 2002 6 speed without traction control.
When i come to a stop the low traction light comes on and my brakes pulse, and after that abs inop comes on to...... What can the problem be?
Import Patrol
Your rear stock size tires should be 275x40x17, If your rear tires are larger than your fronts, It could be throwing off your abs set-up I have the same problems with harder stops though
