Edelbrock=shocks?
Beat98TJ.....
I'm not really very clueless on this stuff. Remember it was me who told you that the kit had Pro-kit rears, not Sportlines.
I don't know every answer, god knows... what do know is the suspensions of these cars, pretty well. And being that I sell Eibach and both LS1 and LT1 Pro-kits, I'm very familiar with both.
They tell you that they rates are the same. Ignoring the fact the free lengths are 15mm different, and the part numbers different, let's think this through for just a minute.
They claim the LS1 set is 1.3" lower than stock, the LT1 1.2" lower than stock. 1/10th inch is 2.54mm. But yet the springs are 15mm different in free height with "supposedly" the same rate. Hmmm... makes me think that at minimum you'd see a 15mm difference in ride height (and we generally do at least between the two springs). So, what information that Eibach is giving you wrong?
If it was the same spring in the rear having a different part number for the rear is silly, but they do. We know they don't drop the car nearly the same amount, and that Eibach's QC is poor because some sets of LS1 springs slam the car so far, yet others don't.
You work for Edelbrock, and I can appreciate you trying to prop up what you guys sell. However, you have 18 posts here, and I've been around for a while. Eibach has well known issues with some part numbers. Further, where you rate the spring will effect the rate on a tester. If I took one of my rear springs, which are dual-stage 100-150 springs, but started compressing in at the end of 100 lb rate and into the 150 rate, I could make the spring seem like it's 120, or 130, or 140 or anything in between.
I think you think I've got a problem with Edelbrock. I don't. Again, I sell Edelbrock products (sold a set of Russell lines today in fact). But being in business means I have to give my customers the best advice and information I have. Being independent and buying from WD's vs. direct leaves me the ability to not have to make sales minimums, so that sort of thing doesn't skew my recommendations or opinion.
You convince me that I'm wrong. Eibach's word means squat to me. I've had other companies tell me plenty of things that just weren't true in the end. While you're talking to Eibach ask them why two different Pro-kits that are radically different on spring rate for two cars that are literally within pounds in actual weight? Ask them why they have such variance issues on LS1 Pro-kits? I'm sure they'll tell you how the LS1 is hugely lighter than a LT1 (it's not fwiw) and that they have no issues with ride heights. It's not true and there are plenty of folks here that have had LS1 Eibach's give up height and rate, despite what Eibach might claim.
As I do not have the LS1 springs here I am inclined to trust the Manufacturer. I have worked with various spring companies and Eibach is one of the more reliable.
It was always my impression that the rear corner weights of the LT1 and LS1 cars are fairly similar. That is why we utilize the same spring for each vehicle. I would have to look at the files, but I recall the same spring having similar rear ride heights when this was developed. I.e. similar sprung weights. The fronts had more of a variation, hence the ride height adjustability that is built into our kits.
As for our spring rater, it does not give a single rate for a progressive spring, it gives a load deflection curve from free to almost block. (Programmable) It will give the rate at any point in the ride height. Also it is a dynamic spring rater that checks the curve while expanding the spring slowly. It is the model often used by Nascar teams among others.
Attached is a data file from our rater for reference.
Unfortunately or LS1 rear springs are long since gone or I would rate both and post the results. I may be proven wrong and I would accept that. Currently I am going off information from the manufacturer.
I have never called your credibility into question. You definitely have more of a proven competition driving record than me. I was involved with the tuning of this application, and I have driven several vehicles with our kits on them over the years. I am merely pointing out that there may be more to our products than you are aware of seeing how you do not deal with them on a daily basis.
If you are offended that I am not actually aware of which springs we are running by trade name, I apologize. We tested both applications and chose the one that worked better for us. It was 8 years ago and several projects ago. I do recall that one worked well while we disliked the other. As we did this testing for all the vehicles we worked with I checked and the vehicle we used the sportlines on was the Mustang.
I do have a question, and feel free to not answer or answer by pm, but have you ever driven an F-body with our suspension kit on it?
Have a nice evening,
Frank
Frankly, I've often wished that you guys would make a normal set of shocks. In this day and age with Bilstein dicking up their valvings it's left us with few options that aren't pretty poor for controlling lowering springs decently when Koni's are not an option. But for whatever reason Edelbrock saw fit to only offer the current setup with coil-over on front, but no damping adjustment and no damping, or ride height adjustment and little option on spring rates in the rear. From a driveability standpoint, I'd much rather have flexible dampers than the ability to raise and lower just the front end of a car (really I don't care much about being able to raise and lower either end at will).
I'll tell you now that if Edelbrock were to make a cost-effective set of dampers that would accept (and work well with) lowering springs that are most commonly used, I'd probably sell a bunch of them. How's that for not being anti-Edelbrock?
But as it is $675+ for set of non-adjustable dampers that leaves me still having to buy rear springs isn't a great bargain, especially when not everyone wants lowering springs, let alone adjustable only front ride height.
If you'd like contact me personally so we can further discuss this, that'd be fine with me. But here I am on record saying if you can get me a set of shocks in the $500 range..... where the gap needs filled with the Bilstein issues to also preclude me from doing Revalved versions for lowering springs, I'd be willing to entertain the idea.
Edelbrock has prototyped standard rod up dampers for the Camaro as part of our private brand program. We manufacture shocks with a piston similar to Bilsteins for several companies under their labels. Our branded marketing push has been to push the IAS.
We are now making externally adjustable dampers for the street rod market, and we may move that technology into other arena's. We have made externally adjustable monotube dampers since 2000.
Frank
Today 4 Dec '10, I installed a set of Edelbrock IAS Performer Coil Over front struts (part# 33031). Very easy to do....MAYBE about an hour per side taking my time. The Struts come with directions to install. Just follow them. They are the same as the Haynes and Chiltons manual direction. Only thing I did diffrent was I did not disconnect the lower steering knuckle. Didnt need to. Like anything else you fix or mod, manuver it the right way and it will come out. Watch the brake lines.....unless you want to remove the caliper. Ialso installed the Edelbrock IAS Performer Shocks (part# 34031) in the rear with Eibach springs (part# 5246) about 2 1/2 months ago, and felt a differance right off the bat from the OEM shock and Eibach Sportline 271915 Spring. I will let you guys know what I think of the front setup in a month or so, but as of know with about 10 miles on the I love them
I'm more/less wondering about experimenting with them on my pickup. But I'll need something with longer travel seeing as I'll be lifting it soon.
