Z06 Calipers Question
Old Sep 5, 2005 | 05:45 PM
redtransam02's Avatar
Question Z06 Calipers Question
I know that the Z06 front calipers will fit on the trans am but im wonderin bout the rears will that fit without modifications or will they require some??
Old Sep 5, 2005 | 07:27 PM
01 Red WS6's Avatar
the rear calipers are the exact same as the ones we have. There isn't a difference between them so yes they will fit
Old Sep 5, 2005 | 08:06 PM
k wut bout them fittin under 17" torq thrust II's im not changing the size of the rotors or anythin so will they fit, mainly askin bout front
Old Sep 5, 2005 | 10:33 PM
trackbird's Avatar
Not exactly, start here:
http://frrax.com/rrforum/index.php?a...05&hl=caliper&
Old Sep 6, 2005 | 02:59 PM
Thanks for the info trackbird. I guess my only main question is on the front can I still use my stock size rotors cause i have read several post of where they would fit an some sayin that you would need a bracket. And also if they will fit with my stock rotors will it fit under my torq thrust II's. They are 17x9.5 I guess that is the main question???
Old Sep 6, 2005 | 03:04 PM
trackbird's Avatar
You can use them with the stock rotors. It will change your brake bias slightly to the rear (the rears will do slightly more work than before and the fronts will do slightly less), but it seems to be a small change that most don't notice.
Or, you can use a conversion bracket and switch to the C5 rotor, caliper, pad abutment bracket, brake hose, etc and upgrade your brakes. This is the more expensive option, but it will perform better. It all depends on your budget, but to answer your basic question, yes, you can bolt the C5 calipers onto your stock brakes on and LS1 Camaro/Firebird.
Old Sep 6, 2005 | 03:58 PM
Aight I appreciate the help trackbird.. Prolly wut I do before I get to much more involved in this is to see if I can find that anti rattle spring first that way I know I can get them an use them first since they had a problem finding one as well.. But I appreciate the info though...
Old Sep 6, 2005 | 05:46 PM
trackbird's Avatar
Good luck!
