shocks to match pro kit
Old Sep 15, 2005 | 02:03 PM
Doski's Avatar
Default shocks to match pro kit
Wich shocks would work good with my eibach pro kit springs? i was thinking bilstein hd?
Old Sep 15, 2005 | 02:34 PM
iroc626's Avatar
I've done some research on this and most people state that Bilstein HDs w/prokit (or any other lowering spring) are minimal. In other words they'll work ok. Bilstein revalved shocks are much more recommended. I've also been told KYB AGX will work better than HDs and Koni SA will work best. It really all depends on your budget and/or preference.
Old Oct 17, 2005 | 09:41 AM
Doski's Avatar
Kyb or bilstein hd?
Old Oct 17, 2005 | 10:46 AM
Judd's Avatar
Great match but cost alot- either the SA or DA Konis. Good match, Bilstein revalves. Decent match and slightly cheaper, SLP revalves. The minimal {IMO} that will work OK is Bilstien HDs. This is the cheapist unless you find a set of the others slightly used, which is the best scenerio.
Old Oct 17, 2005 | 02:32 PM
jmm98LS1's Avatar
I've got KYB AGX with my pro-kit and I like it a lot. The handling is awesome and not harsh at all.
Old Oct 17, 2005 | 10:10 PM
FstBlkz28's Avatar
I've got Koni SA's up front and Bilstien HD's in the rear w/ my pro kit and it is a VERY good combination. I'm very happy w/ it.
Old Oct 17, 2005 | 10:59 PM
DONAIMIAN's Avatar
My bilstens are blown up front, so im gona say koni. That is unless you get a set of revalved bilstiens.
Old Oct 17, 2005 | 11:58 PM
Silver Knight's Avatar
I use the fully tunable Koni and I believe it has the best handling (street racing) and comfortable ride. Good Luck.
