QTP's w/ flowmaster merge... DS saftey loop?
Old 09-19-2005 | 01:06 PM
35thls1ss19's Avatar
Default QTP's w/ flowmaster merge... DS saftey loop?
I was looking to get a torque arm and i like the new UMI one... but it will not work with the DS saftye loop. What are you guys useign for a loop and a TA? thanks alot
Old 09-19-2005 | 05:47 PM
UMI Performance's Avatar
Hello,
We have actually confirmed the tunnel brace mounted torque arm below to clear with the Flowmaster merge collector with NO loop. I am pretty sure the loop will not clear. Your other option is the second torque arm below, if you didn't want it mounted to the tail shaft we have a relocation kit coming out in 3-4 weeks. We will have pictures of the new torque up tomorrow. Please ask if I can help anymore.
Will clear with no drive shaft loop
http://www.umiperformance.com/2202.aspx
New arm just released
http://www.umiperformance.com/2205.aspx
Thanks!
Ryan
Old 09-19-2005 | 06:49 PM
Originally Posted by UMI Performance
Hello,
Thanks!
Ryan
is there another ds loop i can buy that would work and then get your ta without the loop? thanks for the help
Old 09-19-2005 | 08:41 PM
I am not sure if there is a loop that will work with both to be honest.
One thing I can do is ship the loop in pieces and you can weld it on once everything is installed and the location is determined. This is about the only alternative I can think of at the moment.
Let me know if that helps, thanks!
Ryan
Old 09-19-2005 | 10:02 PM
anybody else no a DS loop that will work?
Old 09-20-2005 | 10:50 PM
Hardtop00SS's Avatar
I have the lakewood loop with my Mufflex Y and it works awesome, BARELY clears, but it works fine. I am running stock TA also so I am in the same boat as you, I like the UMI tunnel mount, but I want a DSL, so I guess I will go with a tranny mount and get the relocation kit.......
