WRONG Caliper??
Old Sep 25, 2005 | 03:54 PM
Vertigo's Avatar
Default WRONG Caliper??
I ordered a new front driver side caliper for my Z28 and once i took the old one off i noticed they aren't the same...What is going on??? Obviously the shiny one is the one I bought but look at the spacing between the pistons?
Old Sep 25, 2005 | 04:20 PM
mitchntx's Avatar
18042491 and 18042492 are the GM part numbers for the 98+ V8 F-cars ...
Old Sep 25, 2005 | 07:01 PM
Vertigo's Avatar
you think i have C5 calipers?
Old Sep 25, 2005 | 07:40 PM
mitchntx's Avatar
No, I think you might have V6 calipers
Old Sep 25, 2005 | 09:27 PM
trackbird's Avatar
The V6 should be the same as the V8 from 98 and up (as I remember, am I wrong?). That actually looks like the set that came off of my friends 99 Mustang GT when we swapped it to the 13" cobra brake kit. I can't swear that it's a ford caliper, but it sure looks like one.
Old Sep 25, 2005 | 10:15 PM
spy2520's Avatar
are the pistons smaller? I see the spacing difference but i think the c5 calipers just have smaller pistons, nothing else. so they may not be c5 calipers.
Old Sep 26, 2005 | 12:03 AM
jargan04's Avatar
It's not a V6 or a vette calipers. The V6 ones are the same as the V8 ones. The Vette ones are the same as both but pressure cast with smaller pistons. I think that is a mustang caliper, like trackbird said.
Old Sep 26, 2005 | 06:22 AM
mitchntx's Avatar
Finally got the experts in here ...
V8 and V6 calipers the same, huh? Learn something new everyday ...
Old Sep 26, 2005 | 07:23 AM
trackbird's Avatar
As far as I know, GM used identical brake parts for both cars (why stock two sets of parts?) and the new CMC guidelines state you can swap to "any 98-02 front brakes (and possibly rears)". Al had a thread on it in frrax.
Found it:
http://frrax.com/rrforum/index.php?act=ST&f=2&t=2513&
The Mustang caliper was on a smaller rotor, and you have to push the pistons together to get them to fit within the radius of the smaller diameter rotor. That's my best guess (only because they look familiar).
Old Sep 26, 2005 | 08:07 AM
Vertigo's Avatar
http://www.madvet.com/shop?frame=1.114.2921
Check out that link...those calipers appear to be what i have on my car. check out the above pic.
Old Sep 26, 2005 | 09:25 AM
jargan04's Avatar
I could be wrong Mitch, but the calipers look the same from the outside. I have not checked the part numbers to see if they are the same. Why would GM go to the cost and trouble to make a different V6 front caliper? When it's just as easy to put the same ones on as there LS1 counter parts.
Old Sep 26, 2005 | 09:27 AM
mitchntx's Avatar
ok, ok, ok ..... I said I learned something new ...
Old Sep 26, 2005 | 09:46 AM
jargan04's Avatar
LOL.
Old Sep 26, 2005 | 10:09 AM
Vertigo's Avatar
is there a difference b/t ZO6 and C5? maybe i have ZO6? Plz refer to the replied post...
Old Sep 26, 2005 | 10:12 AM
jargan04's Avatar
Only difference between C5 and Z06 is red powder coat.
Old Sep 26, 2005 | 12:31 PM
trackbird's Avatar
The C5 and Z06 (C5 Z06, not C6) calipers have 40mm pistons. LS1 F-body brakes have 44mm pistons. I forget what the mustang has.
Old Sep 26, 2005 | 06:52 PM
regalgs97's Avatar
Actually, the LS1 brakes are 44.9 MM. I actually measured the ones I bought b4 I put them on. The .9 MM makes a difference, 125 MM area total.
Old Sep 26, 2005 | 09:43 PM
trackbird's Avatar
Sorry, I was using the "nominal" number. I've not mic'd a set (that I can remember). Interesting info.
