Random Tech torque arm install help
Old Oct 1, 2005 | 08:02 AM
ls1z4me's Avatar
Default Random Tech torque arm install help
I am having a hard time getting the factory TA bracket ( with rubber removed) to clamp around the new urethane bushing on the Random Tech torque arm.
I got the car w/o motor and trans so I dont know for sure if this TA requires a special bracket on the trans. or not.
Old Oct 1, 2005 | 12:48 PM
98boxer's Avatar
If im understanding correctly -I may be not, im sorry for confussion- you are putting a poly urethane on the t/a, removing the factory bushing, right?
Ok, I did the same thing and put a ployurethane bushing and YES, it is a difficult process to get the bracket to close with the new urethane bushing.
To get the bracket to clamp, was a pain in the ***, arms, fingers, back and came with a lot of stress and fool language. What I had to do was trim VERY little piece of urethane bushing at the botttom of the t/a clamp so it can close with a bit easier. Because if I remember correctly, when you close the bracket with the urethane installed their is a little lip that is almost impossable to close with out trimming the lip a little.
Hope this helps.
Old Oct 1, 2005 | 04:43 PM
Sam Strano's Avatar
LS1TECH Sponsor
Grease the outside of the bushing.... The clamshell will close right up.
Rookies.
Just one of the things I tell any of my customers when they are buying a TA that uses a urethane bushing.
__________________
