Is gravity bleeding the brakes okay?
Old Oct 4, 2005 | 03:01 PM
2000SSNB's Avatar
Default Is gravity bleeding the brakes okay?
Hello,
I have a 200SS with stock brakes and want to change
the fluid. Can I just gravity bleed (need to do the job by myself) carefully or will this not work? The car does have
ABS.
Thanks,
Gert
Old Oct 4, 2005 | 03:40 PM
01 Red WS6's Avatar
I've done it on my car and it worked out great.
Old Oct 4, 2005 | 05:11 PM
rbobryk20's Avatar
ive read on this and is it as simple as it sounds? just open all four bleed screws and make sure the master cylander stays full? Is that it.
Old Oct 4, 2005 | 05:16 PM
spy2520's Avatar
thats what i did, but just on the front. i havent touched the back yet.
Old Oct 4, 2005 | 05:24 PM
MW2 Performance's Avatar
It should by fine, but when you do your final bleed, as with most ABS systems, you have to bleed the farthest from the ABS unit, to the closest, on our cars that means, right rear, left rear, right front, left front. Have fun!
-Mark
Old Oct 4, 2005 | 07:51 PM
01 Red WS6's Avatar
I did only two at a time. I did the back two 1st then when they finished I did the front two. It was easier to keep the master cylander full that way... Other wise I would have had to check it more often
Old Oct 4, 2005 | 07:57 PM
V6 Bird's Avatar
Originally Posted by 2000SSNB
Hello,
ABS.
Thanks,
Gert
I used a mighty vac hand pump and did mine that way...Way faster and less of a mess.
Mike
Old Oct 5, 2005 | 04:05 AM
2000SSNB's Avatar
Thanks for the replies. I'll do it carefully this weekend.
Gert
Old Oct 6, 2005 | 08:04 PM
2000SSNB's Avatar
Just wondering how long each side will take to bleed
with new fluid, 10...15 minutes?
Gert
Old Oct 7, 2005 | 01:08 AM
Just go untill you see clean fluid.
Old Oct 7, 2005 | 01:29 AM
01 Red WS6's Avatar
it doesn't take long at all. I don't remember exactly but it wasn't long
