BMR tube SFC / BMR bolt-in relo compatibility
just as the subject line says: I am wondering if you can use BMR's relo brackets for the LCA's with the tubular subframe connectors. I got to looking at it last night when my car was on the lift and I'm not sure if I'm supposed to weld the SFC to the bracket since the bracket should sit 'around' the current LCA mount where the SFC would normally weld to. I'm just posting this as a precautionary measure to make sure it is ok. will someone post up if this can be done? pics would be awesome too if anyone has any. I haven't found a write-up with pics of cars which have both done.
Thanks.
Thanks.
LS1Tech Premium Sponsor
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
Thanks.
Thanks.
Thanks.
Thanks.
got everything installed tonight. I guess I really didn't look at the instructions too well the first time to see where stuff fit up and I kind of panicked when I posted. It was really pretty straightforward when I was under the car. Haven't got to drive it yet. Still have to change out a torque arm bushing tomorrow....damn I want to drive it...Thanks for your replies Ed and BMR
