Replacing rotors
Old Oct 7, 2005 | 07:16 AM
NemesisLS1's Avatar
Default Replacing rotors...need help
Ok, So am replacing rotors, brakes today and I cant get the damn rotors off. Is there something I am missing here?
After I take the caliper off the rotor should just slide off the spindle right?
Maybe after some beating on it possibly?
Let me know...
Old Oct 7, 2005 | 08:30 AM
LightweightZ28's Avatar
Yeah, I have had to beat on mine with a rubber mallet before to get them off. If they have been on there for a long time they tend to get stuck on there. Nothing abnormal about it.
Old Oct 7, 2005 | 09:08 AM
Kenafin_02TA's Avatar
I think I had little groved washer things over some of the studs, you get those off too?
Old Oct 7, 2005 | 10:19 AM
01-6spdZ's Avatar
if there still original they will have little washers to hold them on. Just take those off
Old Oct 7, 2005 | 10:37 AM
jmm98LS1's Avatar
I had to smack mine pretty good with a hammer to get them off.
Old Oct 7, 2005 | 12:21 PM
3rdgentug's Avatar
mabey i missed something but you are talking about rear rotors and not fronts right? rears should come right off, fronts you have to pull the hub, take out the kotter key remove nut.
Old Oct 7, 2005 | 04:29 PM
Pewterpower's Avatar
Huh? You talking 3rd gen or 4th gen? Regardless, there is NOTHING holding the rotors on, on a 4th gen. They are sandwiched between the wheel and the studs. That is why proper torque and the "star" method is so imortant when putting your wheels on.
Old Oct 7, 2005 | 06:51 PM
NemesisLS1's Avatar
Sweet!
After getting off of work today I came home checked the forum and went pounding away.
There were no nuts on the rotors but they have to be original because of the condition they were in.
I used a 15lb weight and pounded the **** out of them untill they popped off. Hopefully I didnt hurt anything else while doing that much pounding. It took a good half-hour to get the fronts off. Tomorrow I am going to finish up the fronts and start on the backs.
Thanks Guys!
