Need rotor pics
also will the C5 brakes make a difference? can you just get the calipers rotors and mounting brackets off a vette and they bolt on or is this the same setup thats on a F-Body?
C5 rotors are 13", f-body are 12". Calipers are similar, but use different pads and PAB.
There are 2 main kits to mount 13" rotors on the f-body.
"Trackbrackets" and the UMI brackets require cutting, vette PAB, vette calipers and vette pads.
The LG kit is a braket that requires no cutting and you can use the f-body calipers and pads.
Most of the time you just need more aggressive pads. If they are not enough, add brake ducts. If that is not enough, go with the 13 rotor. If that is not enough, then you need to look at the BBK's. (big brake kits).
https://ls1tech.com/forums/suspension-brakes/271856-c5-rotors-my-t.html
https://ls1tech.com/forums/suspension-brakes/374111-c5-brakes-01-f-body.html
Slotted/Drilled Rotors
(Mostly for looks)
https://ls1tech.com/forums/suspension-brakes/379657-rotors-pads.html
C5 Brakes
https://ls1tech.com/forums/suspension-brakes/325196-corvette-brakes-f-body.html
