Upgrading my stock suspension... Any sugestions??
This past spring I bolted on a ton of new mods to my 01 WS6 and made 425RWHP and 391 RWTQ. Now I have a Moser 12 bolt sitting in the garage along with a Spec stage III clutch that I plan on installing this winter while the car is in storage. I figured while I have the rear end dropped I might as well up grade the rear suspension while I'm at it. I need some advice on what suspension upgrades I should go with first to help get this power to the ground. I realy like BMR's stuff. Also you should know that in the future I plan on adding an aftercooled Procharger D1-SC. My goal is to go mid 10's and keep the car streetable (drive on the weekends and stuff). One other thing... I would apreciate any advice on a good aftermarket drive shaft too. Thanks.
You can't go wrong with BMR or UMI. For 10s, I'd recommend Lower Control Arms, Panhard Bar, Torque Arm, Subframe Connectors, Swaybars, and matched Shocks/Springs. Might consider an airbag as well.
Mark Williams, Denny's, and ACPT make quality custom driveshafts in aluminum, steel, or carbon fiber with 1350 U-joints, which is perfect for the 12-bolt. The Carbon Fiber from Mark Williams and ACPT run about $800, and Denny's has a popular nitrous ready steel driveshaft that runs for about $400.
Originally Posted by BMR Fabrication Inc.
Give me a call or email me. I will be more than happy to answer any questions you have regarding our products!!
Lee Spicher
lee@bmrfabricatiion
(813)986-9302
Lee Spicher
lee@bmrfabricatiion
(813)986-9302
I have all UMI stuff so far. Single adjustable LCA's, single adjustable Panhard Rod, and tunnel brace mounted torque arm, and so far I love it all. I know my next step is to get some QA1's with the 300 lb. springs, those will go up front but it'll still help.
Originally Posted by Hotrod God
I sent you an e-mail yesterday around noon I think Lee. I want to do all the work myself. Could you recomend a book or web site that I could get info on how to install and adjust the suspension parts. Thanks
Lee Spicher
lee@bmrfabrication.com
(813)986-9302
Originally Posted by BitViper
Install University
great website
Lee Spicher
(813)986-9302
sent you an email back today!! just let me know
Yeah that is a great place for me to start. Thanks. I want to stay as light as I can. Do most of thoes components come in chrome moly?
Lee Spicher
lee@bmrabrication.com
(813)986-9302
Currently I am still saving up the $$$. I hope to have all this purchaced and installed by April. I will be contacting you when I am ready to make the purchase. Thanks for all your help.
Bilstein HD's, stock springs, 1LE rear control arm bushings, and Spohn chrome-moly subframe connectors--that's only around $500 in parts with no side-effects. I'll let you know in a few months how they helped.
