For those who want to see ride height after springs
Old 12-09-2005, 05:19 PM
02perfect's Avatar
oops, forgot, the kits include adj. collars, sleeves and eibach springsand are around $400 for all 4 corners. unless you're doing some serious racing, the GC's are plenty sturdy for most applications. the qa1's are a nice set-up, but they're also $2000.
Old 12-11-2005, 07:09 PM
StripedZebra's Avatar
My car is on sportlines, havnt measure or anything. You can browse my photobucket in my sig for a pic that you like if you want to use mine as an example.
Old 12-14-2005, 05:01 PM
Cal
Cal's Avatar
Originally Posted by 02perfect
96 lt-1,
google ground control coilovers and you'll get hits for suppliers, hopefully one will be a sponsor.
all you need to be aware of is there is a kit designed specifically for your year/shock set-up.
good luck.
The best supplier of Ground Control stuff is Strano performance. Sam has a lot of experiance working with them.
Old 12-24-2005, 11:10 AM
WayneSS01's Avatar
Revalved Bilsteins and LT1 pro kit from Sam Strano
17 x 9.5 - stock tire size - no adjustable panhard bar
https://ls1tech.com/forums/suspension-brakes/279119-pro-kit-bilsteins.html
Old 12-29-2005, 10:43 AM
Angus's Avatar
Here is my car with the bilstein level ll suspension option from SLP with my stock 17x9 and 275/40/17 wheel & tire with 300 miles on the car...(both pics full tank of gas)
Here is same thing with Kumho MX's 275/40 front and 285/40 rear with 34k miles on the car.
The following users liked this post:
Vincent Wright (03-17-2021)
Old 12-30-2005, 11:45 PM
jwhert's Avatar
is that red ta at the top just the ls1 sportline kit, the rest stock suspension?
Old 01-03-2006, 04:18 PM
Lethalchem's Avatar
Interesting thread. Thanks for the pics. I've got Eibach pro on mine, and it looks very similar to their sportline set.
Old 01-03-2006, 06:06 PM
jwhert's Avatar
the stance of your camaro =
Old 01-06-2006, 12:10 AM
99TransAmM6's Avatar
full qa1's coilovers up front and 12 way adj. qa1 and cut dms' springs in the rear...pretty low with my pacesetter lt's and 3.5 y with the "resonator" right behind it...prolly inch and half off the ground or 2 inches
yeah whoops posted this on my friends name...actually 2fast97z
Old 01-06-2006, 02:44 PM
Carlos01SS's Avatar
I'm surprised I didn't add my pics on here!
Okay before the change I had factory SS(Read Z/28) suspension, front height was 27-3/4 inches, rears 27-5/8"...
Now with GC Coilovers, I set the ride height to 26" fronts 26-3/8" rears, 500# front springs 150# rears...
Old 02-04-2006, 07:25 AM
SOMSS's Avatar
Here's my SS on Hotchkis springs, supposed to be 1" drop, really - 1 3/4" front and 1 5/8" rear. I will be installing VariShock SA coilovers next month. Picts will follow.
Old 02-07-2006, 10:00 AM
  #32
Mr. Trick's Avatar
Has anyone removed the rear isolators on a car with stock suspension? I want to eventually lower my car, but I cant afford it right now. Will removing the isolators more or less make the car look leval? Also does anyone have pics if they have done this? And how will it affect ride quality, I know I cant have the same ride as a cadillac bu the roads around here are terrible.
Old 02-07-2006, 12:09 PM
  #33
scrmnws6's Avatar
What are rear isolators?
Old 02-07-2006, 07:03 PM
  #34
Mr. Trick's Avatar
The spring isolators. I see alot of people with the DMS kit just use heater hose I was wondering if I could do the same with the stock springs.
edit: I found a thread regarding this a few threads down. But pics would still be nice.
Old 02-07-2006, 09:29 PM
  #35
skewba98z28's Avatar
Yeah you can do the !ISOLATOR! mod on stock springs. I think that if you didn't do the front's though your rear would sit lower. When I find some time I'm going to put the stock springs back on my car in the rear with the !ISOLATOR! mod and leave the front eibachs on. Just hunt around. I'm sure you can find some front springs pretty cheap. Just be sure to get new shocks and struts when you lower your car.
Old 02-25-2006, 12:02 AM
  #36
BORICUA420's Avatar
Default What's up !!!!!!!
here's a foto of my car dropped 2" sitting on 20"s , I'm a new member here looking foward to trading tips
Attached Thumbnails For those who want to see ride height after springs-fotos-fe-alex-066.jpg   For those who want to see ride height after springs-fotos-fe-alex-067.jpg   For those who want to see ride height after springs-camaro.jpg   For those who want to see ride height after springs-camaro-.jpg   For those who want to see ride height after springs-camaro..jpg
Old 02-28-2006, 02:59 PM
  #37
777
777's Avatar
Eibach pro-kit, stock shocks (probably need replacing)
Old 03-06-2006, 09:13 AM
  #38
RollTideTA's Avatar
Here is my 2000 WS6 right after the swap:
- stock tire/wheel sizes (17x9.5 275/40 x 4)
- LT1 Eibach Pro-kit springs
- Revalved Bilsteins from Strano Parts
Old 03-17-2006, 11:09 AM
  #39
mulletwearingtadrive's Avatar
any pics of an fbody with the eibach launch spring kit?
Old 03-24-2006, 01:24 PM
  #40
ibanez7's Avatar
two picts of my car, with cut springs. I cut off 1 coil all the way around. I wish I would have cut 1.5 or 2 coils. But this is fine for now, soon I will buy new springs anyways!
the top of wheel to wheel well distance is the same as SLP lowering springs.
Quick Reply: For those who want to see ride height after springs
