umi phr doesn't fit
umi phr doesn't fit
I'm getting the finishing touches on my 9" install and my phr (umi on car adjustable w/ one rod end) doesn't fit onto the new rear end. The poly bushing fits onto the car perfectly, but the bolting point on the rear end is too narrow to accept the rod end. Has anyone else run into this problem and had to use some grinding to get the phr to fit?
We have found that most (esp. Moser) rear-ends have very sloppy tolerances. We have found ourselfs having to use a pry bar many times to spread the mounting brackets for the panhard bar to fit, this is very common. I am pretty sure this is the problem and recommend trying to spread the rear-end bracket slightly instead of grinding the panhard bar bushings.
Hope that helps!
Ryan
Hope that helps!
Ryan
Originally Posted by UMI Performance
We have found that most (esp. Moser) rear-ends have very sloppy tolerances. We have found ourselfs having to use a pry bar many times to spred the mounting brackets for the panhard bar to fit, this is very common. I am pretty sure this is the problem and recommend trying to spread the rear-end bracket slightly instead of grinding the panhard bar bushings.
Hope that helps!
Ryan
Hope that helps!
Ryan
