torque arm questions
There are other ways to resist this torque. With leaf springs, the torque tries to wind up the leaves, but the front portion of the springs resists the torque. With a 4-link or 3-link, the top and bottom links resist the torque.
Yes, the TA also sets the pinion angle. It also helps determine where the "Instant Center" (IC) of the rear suspension is located. The location of the IC determines how much anti-squat you get. This relates to bite especially at launch. A side effect can be wheel hop or brake hop.
In order to answer your question, you should be familiar with IC and anti-squat. Here's an explanation of IC on a Camaro:
This diagram is VERY helpful.
http://www.jonaadland.com/Ta.jpg
In a stock Camaro rear suspension with a fore/aft sliding front mount of the torque arm, the side view IC is found as follows:
Extend a line from the rear pivot of the lower control arm (LCA)thru the front pivot forward past the transmission mount. Next a line is drawn perpendicular to the front end of the torque beam where it is attached at its rubber slider joint. This is basically a vertical line with the car at normal ride height. Where this vertical line crosses the line of the lower control arms is the side view Instant Center.
This is quoted from Terry Satchell, a GM suspension engineer very familiar with this subject.
Note that you can easily raise the IC by dropping the rear pivot height of the LCA. Note also that different ride heights (lowered or raised car) change the IC height. Note that lowering the rear drops the IC, and therefore reduces the anti-squat unless LCA pivots are relocated.
My thanks to Jon Aadland for the picture.
Aftermarket TAs are shorter so they move the IC rearward. Going even shorter than the Sphon TA may just get you into many more problems than it solves. Remember that the shorter the arm, the more load it puts into the mount on the body/chassis.
I'd advise against going any shorter that the Sphon. A much better idea would be to modify the exhaust system. A good Y-pipe and a 3 inch single behind it should be sufficient for your engine unless you get WELL past 450 rwhp. Then just increase the size of the single pipe and muffler of course.
My $.02.
If you are concerned only about the trans case, check with other folks running the kind of rwtorque you expect. Remember available traction determines load on the torque arm. If you are planning to see sub 1.50 60' times the torque arm might be the least of your rear end problems.
My advice is to not design your own torque arm. Either use the stock one, or buy a well-proven aftermarket one. When you upgrade to a stronger rearend would be the time to change torque arms, IMO.
Good luck!
I suggest every race vehicle enthusiast own a copy! The workbook also helps a great deal.
