Shock and swaybar packages
Old Nov 18, 2005 | 02:51 PM
rob c's Avatar
Default Shock and swaybar packages
Have the Eibach Prokit lowering springs installed (see sig), SFC, STB, and wider tires in the rear. The car pushes (understeers) big time now. I want to keep the wider rear wheel/tire, but I want the car to be more neutral/balanced. I will probably replace the shocks with Bilsteins, but Im wondering if the 1LE front sway bar will help balance things out a bit...the car is a backup car/garage queen right now, but Id like a combo that works well on the street and also offers good performance for an occassional track day. Thanks for your suggestions on shock and swaybar combos!
Old Nov 18, 2005 | 06:29 PM
jimmyblue's Avatar
Moderator
Get Strano's hollow sway bar set and let him revalve
a set of shocks for your overall combo (if you don't
want to spend the even longer dollar for adjustables).
Old Nov 18, 2005 | 11:27 PM
rob c's Avatar
Thanks, I'll look into it!
