Shock Tower Brace
THEN I put on the Eddlebrock STB. It works just fine and I notice the difference.
Maybe if you don't then you aren't cornering near the limits? if you aren't in at least NEAR a 2-wheel or 4-wheel drift, you won't notice the STB ... and, if you aren't and don't, then you don't need one.
I don't drag race, even for fun. If I did, an STB would be useless weight since the track is a straight line (of course, so would the heavier antisway bar). If you like road courses or autocross, then the STB helps. I like hard cornering. Acceleration is good, but only if it helps the lap times. Spinning the tires while cornering or sliding them only slows you down most of the time.
Then again, that is the entire reason for sport of "drifting." Personally, I'd rather lap a drifting car than drift the entire course ... it's faster. Drifting might be FUN, but only if someone else is paying for the tires and engines! If I'm paying for them, I want to stop short of spinning the tires and corner with all the force that is possible in an F-Body. The STB helps me do just that.
So do the Bilsteins ... and some good throttle control.
I autoX on 13 inch wide sticky tires, and I couldn't telll the difference either, so I sold my STB. There was also a guy that attached strain gauge instrumentation to one and measured very little force going though it. The fact is STB's are a placebo that only adds weight to the car. Sorry for the bad news . . . but the good new is some people think they look cool, so you can probably sell it, and your car will be lighter, which really does help handling, braking, and accelerating.
I've seen a 4th-Gen F-Body with the shock towers loose enough to bend at the top when encountering a small drainage ditch.
Thanks, I'll keep mine. You have fun without one.
Nothing wrong with having a brace. But like SFC's, I simply feel they are done before much more pressing matters.
Not because I favour the man's opinion, but I will once agree with Sam on this one, because my vehicle was bought with a previous wreck on the front left fender, and guess what? I had the monocoque checked and there was no evidence of anything previously out of alignment from the chassis at the shock towers, so those examples you state must be from something extremely serious.
Another aspect I should mention is that I've indavertantly collided with many dips, bumps, deep drainage ditches, curbs, severly elevated speed berms, and the only thing I've seriously damaged were the spindles and lower A-arms. Shock towers? They've been okay, and not once have I had any trouble with them nor had a STB installed. Also there's been no paint chipped away from any part of my hood, except some on the top from road debris and some underneath from the previous stock air filter box, all being very minute in size.
Your description appears to describe the 3rd Gen, which I have partially experienced what you mentioned.
http://i11.photobucket.com/albums/a1...2/DSCF0111.jpg
