Should I get polyurethane bushings for my 35mm sway bar???
I am going to install my 35mm sway bar soon and was wondering if I should use stock rubber mounts or polyurethane ones?
It's a daily driver with Koni DA's, BMR Subframes and Boxed Panhard rod and LCA's.
Any information on what the differences would be is much appreciated!
LS1TECH Sponsor
What kind of bar is it? Because all the aftermaket bars come with new urethane bushings already.
__________________
That's the problem, I don't know.
I have a friend in Florida who just bought your bars for my old car, a 1999 Trans-Am (he also got you Koni package, his name is Spencer) and he loves it so I wanted some.
My other friend in Florida knew I had already got the Koni DA's and was going to get your bars as well.
Apparently he had a 35mm bar off a car that he is going to give me as a Christmas gift but no clue as to what brand it is, just the size.
I'm not sure if he's sending the bushings or not but I was going to replace them regardless.
I was trying to decide between the poly's or the rubber one's SLP has.
My main concern is noise. It's a daily driver.
Since you're here Sam
, where on your website can I order the rear bar? I didn't know what manufacturer to look under since I thought you made them...
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
Originally Posted by NHRAMAN
All new bars come with poly---get rid of the rubber... ![Barf](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_barf.gif)
-Mike
LS1TECH Sponsor
A poly bushing that's lubed well and with an appropriate lubricant makes noise a non-issue. Go Poly. Most likely the bar is an ST bar (pretty much has to be by description). And I can get you those bushings and brackets if you like. Beware that Energy Suspension no longer makes non-zerk fitted 35mm's. And we have a lot of problems with the zerked types cracking because the hole for the grease is a stress riser and the 35mm bar puts a ton of force on them.
As for the rear bar... It's on the site. Just search search Chevrolet, Camaro, suspension and it'll come up under swaybars. Part number on the site is STR-22mm. I'd link it if I could, but the site doesn't work quite that way. Or, you could just call me, which might be easier. It's $189 plus shipping (which isn't much as it's not heavy).
__________________
Don't want to hijack here, but some have misconstrued Sam's request to call him as being something negative, but I will wholeheartedly mention that not calling him would be a opportunity missed out. I would mention that all of his family has their information togethor and Sam Jr. himself is very patient, polite, and intelligent when it comes to discussing suspension. And if there's any technical problems, they go to great lengths to resolve them.
I'd also mention that the manufacturer of some of his suspension items, Addco, is a top notch company that pretty much works great with Strano's customers as well. Not only were the bars quality pieces that are inexpensive, highly engineered, not over built, but dealing with any defective part issues was a customer service dream compared to many other businesses today.
Sam's customised Addco stabiliser bars are very high quality without the unecessary frills, plus even with my high spring rates and linear valvings, they're amazingly stable.
Since my bars came with poly endlinks, I stuck with them as the manufacturer suggested.
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
LS1TECH Sponsor
Fronts are totally different. Rear will bolt on, but is too large for most applications. It's 24mm, and while some use them you'll note I use a Hollow 22mm rear bar. And I've actually gone to that from the 24 on a number of 3rd gens as well.
__________________
