Anyone using Crossmember Mounted Spohn Torq Arm
I was looking into the Spohn Crossmember Mounted Torque Arm...I was wondering if anyone was running it and what there feeling on the product is...also if anyone has any reviews or suggestions on torque arms...Id appreciate those also thanks
im not lowered and i have clearance issues. its a nice piece, but i feel its more a track only setup. i think im gonna go with a tranny mounted one from UMI or something. This TA is becoming a PITA here recently. Im not too happy with it anymore. The front loop was a pain also, so i cut it off. I still have the rear one though.
I've got it and am lowered. As with any lowered car you just need to be careful where you drive.... I do have a few scrapes on the crossmember brace though. Other then that, I havent had any issues with it.
Originally Posted by ninobrn99
thats the thing. im not lowered and im having issues. Im going with a tranny mounted one next.
I have it and there are 2 things that bother me about it. The cross member section is pretty low, I have a stock ride car and I have a few scrapes in it. Second I got the driveshaft loop in the crossmember and the Y-pipe rattles up against it. I put a piece of rubber in between but that didn't lasted long, I had rig a brace to pull the y-pipe down about an inch off the DS loop. I also had to reverse a couple of bolts that where too close (actually rubbing) to the Driveshaft U joint. Other than that I'm, very happy with it. I still need to make a more permanent solution to pull the Y-pipe down (since I'm still getting a very slight vibration)
I have this piece and I'm lowered with sportlines...... about 1-1/2" from crossbar to ground. Not the exact piece of suspension best for daily driving. I'll agree with a statement earlier that it seems like it's just for track use. The TA is also extremely loud. Includes whinning from the gears and clunks from the frame continuously since the crossbar is pretty much sitting directly below you. I have the rod end which probably wasn't a smart choice and I can always hear it clunk back and forth when I'm sitting in idle and throw it into first or reverse. It certainly dworfs the stock TA in strength and performance but also has a few negatives to go along with it. I'm kind of so so on wheather it was worth it to buy, but sure is no turning back now.
Hi
I have the BMR torque arm relocation kit. It transmits a little more noise and thud, but not anywhere near as bad as a hinged unit like the Spohn. It is a nice compromise.
You still have a semi-rigid mount (regular poly bushing) that is closer to the driver's seat, so when you go over bumps you feel it, but it is mostly quite. I think UMI and Yank make similar units.
I have no clearance problems on a stock hight car. It may be a minor issue on a lowered car. I think you will lose about 1/2" to 3/4" with it. UMI claims their unit has no clearance lose at all. I am not sure if it is out yet.
JA
JA
